Old 06-20-2020, 12:58 PM
CCS has that bearing assembly for 1/2 what that other outfit is asking.
Old 06-25-2020, 02:54 PM
sbuck sbuck is offline
Question:
Does this nut need to be undone in order to remove the stamped housing?
(I'd just take it off to test, but don't have a socket big enough on hand)
I ask because I pulled the spindle off the deck as suggested, and was able to pull off part 6, but part 7 (stamped housing) is seized. I was able to pry it down creating about a quarter of an inch of separation between part 5 and 7, but that was it.
So either it's really seized on, or somehow the nut on top of the spindle is holding it on (seems unlikely as I was able to pry it a bit).
I tried this on both the problematic spindle (middle) and the left spindle for comparison. Both seemed seized.
In other news, I did manage to pick up another 44a deck locally that needs some work, but is in much better shape. None of the deck is rusted through, and the spindles are all sound. And, as a bonus, it appears to have the newer aluminum housing spindles with the replaceable bearings.
Given this, I'll probably abandon fixing the spindle on the first deck, but I still wanted to ask this question as I continue to learn and tinker with my cub cadet. : )
Old 06-29-2020, 11:00 AM
Update: I forced the stamped housing off using pry bars. It bent things up in the process, but at this point the middle spindle was garbage anyway, and I'm moving on to the second deck. I just wanted to tear things apart to see what was wrong.
The reason the stamped housing was stuck was there was a build up of junk/gunk around the bearing. In hindsight, and for anyone else in the same boat, I bet if I used a twisting motion instead of a prying motion on the housing, I may have been able to get it off w/o causing damage.
In dissecting things, I also found that the play was coming from the bearing. I cut it open to investigate, and it was missing some of the ball bearings. How they managed to escape, I have no idea.
Anyway, considering this "case closed" as I move on to the second deck with the newer spindles. Thanks everyone for the input.
Tags
1250, 44a mowing deck
