Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 07-26-2020, 03:04 PM
Probably should have the correct Oil Cap.
Old 07-26-2020, 03:27 PM
Well lookie there,
Roland done went and found a pretty one with a magic Aladdin lamp embossed on it!
Do ya 'pose if you took it off, the "magic smoke"or better yet "Jeannie" would get out?
Old 07-26-2020, 03:42 PM
Originally Posted by Hairtrigger View Post
Well it makes no sense that there is a picture of a gas pump on the cap
But there is definitely pressure under the cap
That is not a Kohler oil fill cap.
Old 07-26-2020, 04:49 PM
Well lookie there,
He was a little late. See post #10. That yellow cap is not an OEM 1864 CC cap.
I would think a vented cap would hurt the performance of the fuel pump.
Old 07-26-2020, 08:01 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Wrong cap , it possibly should also be yellow also with an oil can symbol on the top
That is a fuel cap almost exactly the same as a couple of Ryobi I have , minus the holes
Have you checked the breather hose that runs into the air cleaner ?
https://www.ebay.com.au/i/1436467772...SABEgKHzfD_BwE
That is the cap I mentioned
Oz
Old 07-26-2020, 08:21 PM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
Thanks to everyone for your help and opinions. I have a proper fill cap on order
Old 07-28-2020, 07:02 AM
bugeye bugeye is offline
A few years ago, my 1864 would stumble/die under higher load. The fuel tank, underside valves, hoses and fuel filter were replaced. Still had the engine stumble/die under mowing load going up a hill. Was ok on the flat part of the yard. Plenty of fuel in the tank. I replaced the original square metal pulse fuel pump with an ebay sourced round plastic one. Problem solved. I took apart the metal pump. The rubber check valve diaphragm was deteriorated. No replacement diaphragm available.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 07-31-2020, 07:47 AM
Here is the end result....I purchased the proper oil fill cap and engine now continues to run as it should. It does have an oil smell when it warms up so I am sure the internals are severely worn in the engine
Old 07-31-2020, 03:32 PM
Or what You had for a cap allowed oil to leak on the fins and now it's starting to stink. You may want to remove the engine, pull the tins and give it a good cleaning. Plugged fins cause them to over heat and then they blow the head gaskets.
Old 07-31-2020, 04:59 PM
Agree.................
