Tractor Serial No. 584058 & below used KH-47-124-03 Tractor Serial No. 584059 & above used KH-47-124-09 KH-47-124-03 has no half round notch |
I think he was referring to the aluminum air duct casting the muffler box bolts to. According to the parts look up they are all the same
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
On engines with balance gears the dipstick was on the outside because the gears are right below where the tube is on top of the block without the gears. Once the gears where no longer used the dipstick moved to the top of the block.
Now that makes perfect sense. Amazing, if you drill down far enough, there is always a reasonable answer (well, most always).
