Old 10-05-2020, 02:46 PM
ironman's Avatar
ironman ironman is offline
It looks like this.....
it slides in the top of the tube, the steering shaft goes through the hole.
However they are plastic and become worn with age and you will get some "wobble" from that.
For best results, replace it with a ball bearing, same one that is in your fromt wheels.
On the loose tube, I have had good results using JB Weld but you gotta get everything grease free and that would be no easy task with it in the tractor.
Old 10-05-2020, 02:53 PM
ccmike ccmike is offline
Thank you. Unless its hiding in the steering wheel or has slipped down into the tube, that bushing is long gone.
Old 10-06-2020, 11:07 AM
ironman's Avatar
Never seen one go down the tube (not sayin' it doesn't happen).
Usually they just work their way up out of the tube under the steering wheel and you can slide it down and back in. Again, JB Weld might help if it's there.
