Old 11-17-2020, 09:27 PM
Originally Posted by tinklevision View Post
What about removing the drive shaft and then flipping ? In this scenario would you need to drain ?
No drain as the reservoir full level is below the pump and filter,
You will loose a few onces in the lines, pump & filter.
If you want to remove the driveshaft/coupling no problem if you prefer.
Just put a catch tray under your work area, keeps oil mess to a minimum
Tags
cub cadet 2182, hydrostatic transmission, leak
