Old 12-21-2020, 10:45 AM
Ambush Ambush is offline
IF you are lucky and there is sufficient oil in the diff/reservoir, and the pump input shaft is turning, then two likely causes are the charge pump key is sheared or (worse) the pin in the trunnion shaft for pump swash plate control.
Hold the pump shaft with vice grips and try to turn the drive shaft. That will determine if the input coupling pin is sheared.
Old 01-02-2021, 10:13 PM
jfaison jfaison is offline
Thank you for the advice.
I changed the hydraulic oil and filter. The 782 is running great.
Thank you for the help!!
