Absolutely PeterJ, hope it is helpful.
I was a bit unsure about the clearance myself, but it really is enough. No way to turn the starter over, due to the shape. I don't think the motor can move enough against its mounts to cause a short. I would definitely do the ground wire update. If yours is still original, you probably just have a single wire running to the air cleaner bracket, which is insulated somewhat by rubber mounts. It's a really poor ground. Here are the numbers on that starter from my comments section: The part numbers for this starter: 2-2658-ND & 18400NN I have seen references on ebay auctions to: 2658 &18400N I paid $86 + shipping. You will not find compatibility numbers for the 882, 782D or 1512. Also, one last word on this: Ground wires are everything. Before you undertake this, first make sure your engine block is fully grounded. A CC service bulletin suggests adding a 2nd ground of larger gauge wire. |
SaturnV, are those Kubota #s?
I requested a copy of the service bulletin from another member on here. Also, I briefly looked at my 1512 (1986 model?) tonight with a flashlight and my motor mount bracket is heavier than yours. I have one motor mount bracket that connects to all four motor mounts. Drilling a BIG hole shouldn't be a problem. It will be nice to go back to the original battery location. I dig working on dirt bikes but am kinda getting hooked on updating the old Cub. I wish I could find a better deck, leaf bagger, power steering, a three point hitch.........
Saturn V,
Is it possible that the starter you put on is also a generator? Is that what the other wire is for? PeterJ |
Saturn V,
Is yours like this? http://cgi.ebay.com/ebaymotors/New-S...Q5fAccessories Does the drive gear stay engaged while the engine is running? PeterJ |
Yep, that ebay link is the one.
Not a generator, just a starter. If I understand correctly, the white simply provides a continuous current during cranking, for instance the glow plug circuit (not direct power, mind you). Interesting info on the motor mount. I was under the impression the 782D, 882 and 1512 were one in the same, save the paint job and stickers. I'm on the hunt for the rest of my 3-point hitch as well.
Saturn V,
I think I was mistaken in stating my engine mount is different. Is yours like this? http://cubcadetparts.arinet.com/scri...%20144-882-399 |
That link puts up a blank page with the word "undefined."
Here's a drawing of the motor mount from Parts Tree. As you can see, the mounts are made of of several pieces. Part #4 is the left hand mount, and the right (not shown) is what I removed to cut the hole in. There are a number of holes already punched out of these mounts, so you have to be careful adding another. The lower section of the mount, #1, does not need modification. Bolt #5 is the reason the engine must be raised up to get the mounts off. It sits below #1 when assembled. |
Saturn V,
The picture you posted is what was on the link I posted. As far as I can tell, that is what mine looks like. Thanks again for all of your help. Sorry about all of the confusion. PeterJ |
Not at all. Check back in when you get yours done, or if you need any more assistance. I'll periodically check back on this thread.
