Old 01-23-2021, 09:46 AM
MSS7120's Avatar
MSS7120 MSS7120 is offline
yes you found it. I have a attached a photo for the CNH peddle I was thinking about. Best pic I could find.
The photo didn't capture the reverse side of the peddle. I extended it with my mad MSpaint skills.
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 01-23-2021, 09:56 AM
MSS7120's Avatar
This is what my dad has on his CIH farmall35. I like it.
Also may want to check out the you tube videos from I save tractors. He makes a really nice video series about his loader build for his narrow frame. He has a video just about the treadle style peddle he built.
Mark from Minnesota
CC yard cart
Old 01-23-2021, 10:17 AM
MSS7120's Avatar
check this out. from I save tractors..
https://youtu.be/WtLPzACxn-8
Mark from Minnesota
CC yard cart
Old 01-23-2021, 02:50 PM
MSS7120's Avatar
I grabbed some photos. You can see with my 10.5 redwing boot. The cub cadet is a 2185 with two separate. You have to pivot and move your foot.
Mark from Minnesota
CC yard cart
Old 01-23-2021, 03:13 PM
Ambush Ambush is offline
^^^ Thanks for all the pics, guys.
I have watched all the isavetractors vids on his loader build. I like the pedal in the pic with your boot and am leaning heavily toward the heel/toe style. Probably shorten it up about three inches compared to that one though.
I'll have to experiment with having the pivot point above, on and below center for ankle flex geometry. Below being my favored position until I can prove otherwise. I'll have the heel pedal fold up much like a motorcycle kickstart.
Old 01-23-2021, 08:34 PM
MSS7120's Avatar
Your welcome. Hope it helps. I really liked that I save tractor video series. I thought it was very informative. I'm not very knowledgeable on narrow frame tractors. My base is in the 2000 and 3000 series.
Funny you should mention shortening it. On several occasions I have thought that a few inches shorter would be better. I guess it's your tractor, size it for your foot.
Have a good project to both of you Ambush and Getter_Done. Please show photos of your projects as possible. I wouldn't mind building a loader in a few years. I"m sure I'll have questions
Mark from Minnesota
CC yard cart
Old 01-23-2021, 08:43 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
I'm a little late to the party here but would like to put out my views on this.
I most definitely prefer the single-pedal treadle style foot control over the 2-pedal style. Have never been much of a fan of jamming my heel down to get the thing to go in reverse.
Spent many hours over the past few years mowing my grandparent's large yard with my grandfather's Kubota GR2110 SGT. It has that single pedal style and I have to say I really like it. Very easy to go forward and reverse just pivoting your foot on your heel. No need to jam a pedal down to go reverse. I don't have a front end loader nor do I have any need for one, but if I ever do, that would be the style I go for.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 01-23-2021, 09:23 PM
MSS1720, I have a thread going on the loader build in the "Home Made" section. Almost have the boom arms done today.
Old 01-23-2021, 11:21 PM
MSS7120's Avatar
I have seen that thread. Guess that I just didn't put 2+2 properly and figure it was you. I like your hydraulic pump setup..
Mark from Minnesota
CC yard cart
Old 01-24-2021, 11:42 AM
B440? B440? is offline
My vote is for the two pedal style: There's more precision from modulating with the pedal at your toes, which is a simple ankle movement vs. using your heel, which requires upper leg muscles to push down and not much precision.
