Old 02-01-2021, 11:18 AM
ICOM 756 ICOM 756 is offline
I have used a bit of stainless steel scrub pads before.
Worked for me
good idea will look at them for sure
scrub pads work as mentioned, hog hair works also.
The idea is to slow/catch oil particles so they don't get directly spit out with a puff of crankcase air.
Those little filters are prolly a 500% profit, smaller than a match book cover.
I would think nothing that would melt from temperature or nothing that would
dissolve from petroleum oils would be appropriate.
I've seem washable furnace filters that would work.
i wonder the what are they 1 inch clear cheapo fuel filters. cut it open and bingo .. it doesnt go bad under fuel use. so oil shouldnt be issue.
buttttttt................ got me thinking... a lil modded cover with a xtern filter like a old chevy valve cover breather. they make them small enough on some of the atvs and such .. big twins also. mmmmmm
here i go again thinking hahhaha
Old 02-01-2021, 11:29 AM
A strip of fiberglass window screen folded several layers would work.
Old 02-01-2021, 12:26 PM
ironman's Avatar
ironman ironman is offline
I have a number of 18 inch floor buffer stripping pads. I cut them up and use them for various cleaning projects.....but wait....
Viola, they turn out to be the same thing as those little filters and I have used as such.
I'm must be sitting on a gold mine!
Old 02-01-2021, 03:57 PM
another good idea
ok iam not talking to you hahhaha .... gold horder
so they come out as they went in ? one piece ? no signs of melting or anything.. will no they wouldnt would they?.. the heat from buffing probley hotter then the oil..
keep them ideas comming folks...
Old 02-04-2021, 04:22 PM
oL george.. if you come across this. or anyone
what do you think of the cycl wall ??? touch it up with 1000 grit ? or leave it as is ??
Old 02-04-2021, 04:47 PM
Leave it be, just make sure you clean the piston in the ring groove areas as the abrasive material can linger there.
Old 02-04-2021, 06:49 PM
ok sounds good.. tho before i asked on here about this issue. i did touch up the skirt on the piston.
as for the abrasive iam goin to wash this thing at the carwash lol then bring it home and bathtub it then wash it again lol.... kills me all went sooo good till that point grrrr....
thank you for the help for sure.
