Old 02-04-2021, 08:36 AM
ironman's Avatar
ironman ironman is offline
As already mentioned, there are many variations of these steering assemblies.
The most noticeable in the Cubs would be the lengths, however, you can always mix & match where possible.
The 122 and 125 have different pedestal configurations, specifically height, which would require different length assemblies, thus the difference in the 122 and 125 part nubers for the shaft (cam &tube).
The supersede number (703-1085) refers to a COMPLETE assembly, not just the shaft. So it would probably be fine for both tractors.
Old 02-04-2021, 11:17 PM
DSarow DSarow is offline
Default Fixing the threads
Thanks guys for all the ideas. Dale C. gave me the idea of tap inside, and use a bolt. I e-mailed Jeff@parts by Jeff. He absolutely hit a home run. His instructions were spot on. He told me drill size, lube to use, bolt size,how to place washers. It went well, couldn't be happier. Patronize Jeff! Please. No matter the problem or question, its why I really enjoy this forum.
