Old 05-30-2021, 09:51 AM
dale c. dale c. is offline
make the slot longer so you can shorten the rod a little bit more
Old 05-30-2021, 11:08 PM
aagitch's Avatar
aagitch aagitch is offline
there may be something else causing your issue because you should not have to modify anything to get it to work correctly.
Adrian
2072 (789513)
Old 05-31-2021, 09:53 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
Work correctly and work the way I want are different things. CCC is concerned about liability in reverse, as such they limit the speed. I want to back out of a corner quickly and move on. However you are also correct in that things are worn and that there is plenty of lost motion because of it.
edit:
This comment above is coming off snippy and that is not my intent as I value your comment. It's just that the reverse speed on the 3000 series is limited by design in my opinion. This can be frustrating when you are trying to get things done and move on. The wear of plastic bushings are a part of the problem in conjunction with the linkage design.
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
