UPDATE----
In further investigation, the 1862 had two manufacturing runs. * S/N - 800,000 - 821,059 (prod #1) * S/N - 821,060 - 836,000 (prod #2) The Diode was used only in Prod #2. Cub Cadet's Master Wiring Diagrams, only depicts the wiring diagram for Prod #1. (another one of Cub Cadet's anomalies) Since you did not mention the serial number of your tractor, the information I supplied was based on the Cub Cadet data I had on hand. I'll have to find the diagram for Prod Run#2.
Thanks for all the input there folks. Spent the afternoon learning about
Diodes, everyday is a new adventure. After learning that aagtich' 1864 had this diode I started leaning towards it being factory. Like Roland I could not find it anywhere in the diagrams however. SN# on the tractor is 82400 so that makes it run # 2. no diagram apparently, thanks Roland. Can a person put 12 volts direct to this system to check all these indicators and safeties etc ? Or do you have to have Solenoid, voltage sensor and all the other parts wired up? Thanks again Ken |
In simplest terms, a diode is a one-way valve that only allows flow in one direction. If you know plumbing, it's like a check valve. if you don't know plumbing, it's like a one-way street (with suitable constant enforcement, naturally). As indicated, it is usually used to stop back-flow on a sensitive circuit.
![]() I am Goof |
I have a picture of the 1862 wiring diagram and it shows the diode on the no. 1 light. Looks like there could be a feedback problem without the diode.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
Richard:
I can't read nor expand that diagram. Could you please send it to me at: onlyclubcadets@yahoo.com.
Email sent
Yes I can see it, missed that one...
Yet more headaches.
Both the 1440 and the second generation 1862 use the 759-3675 Diode, and use the 725-3185 Indicator Harness. Here is the difference in the Cub Cadet Wiring Diagrams. ![]() ![]() ![]()
Roland, your email server rejected my email
Hmmm maybe only CLUB cadets @ yahoo.com is no good
