Wow
Lucky you caught that. Curious to see what it looks like inside...
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Probably will look like it was on the Titanic.
The last GD Cub I was into did. |
That's what I'm expecting. Although I almost feel like over the past few months the tractor has been working a bit too well for the internals to be a rusty mess. Only one way to find out!
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
If it is rusty it will show its ugliness on the differential ring gear.
What did it turn out to be when you got it out of there? Were you able to drain it or did it have to be scraped? I had some similar-looking gook in a hydraulic reservoir not long ago, and after draining the liquid part I had to open it up and get the rest with a plastic putty knife, then rinse and scrub with gasoline and a cheap brush
It all started with a little 122...... |
Okay, update time. Finally got around to getting this done. So first, I swapped the 106 and the Original so that the 106 could be in the workshop.
IMG_20210305_194122.jpg IMG_20210305_194150.jpg I then removed the fender pan, underneath it's decently grimy but not too bad actually. IMG_20210305_201556.jpg Then pulled the rear cover. Unbelievably, I did not find what we all expected. There was not a single spot of rust inside this transmission! And the fluid was most definitely old Hy-Tran. By the color of it, I would say it might be OEM fluid that the tractor came with from the factory . IMG_20210305_203100.jpg IMG_20210305_203110.jpg Once completely drained and cleaned out, it looked pretty good. IMG_20210305_213614.jpg Under the top cover everything looks in good working order. Shifter forks aren't bent out or anything, and the gears shift properly. IMG_20210305_223434.jpg So, after putting the rear cover back on I filled it with new fluid, SAE 30 oil as the manual states should be used if not using Hy-Tran. Poured it in through the top so that I could coat all the gears with it. Then put that cover back on, and bolted my fender pan back to the tractor. Tomorrow I'll go for the test drive.
Too late about it now, but these bolts sometimes loosen up and you will pop out of gear.
Remember to check tightness next time |
Luck you!!
Alright, test drive complete. Lets just say... that was a huge improvement! Definitely a lot less noise coming from the transmission. Took a pretty long test drive...
Down the street to a friend's shop, where it posed for some pictures. IMG_20210306_110306.jpgIMG_20210306_110316.jpg Then down further to the local farm, and then after helping out in the repair shop for a while, she started right back up and drove all the way back without issue. IMG_20210306_131251.jpg Well, there ya go folks. Always check your transmission fluid. It could be water, or it could be OEM Hy-Tran that's been there since the tractor was brand new
Nice job on the transmission service! Your gears will like that fresh oil and it'll run good. shifting may improve and be smoother too.
Steven __________________________________________ 127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720. |
