Old 03-02-2021, 08:29 PM
jbrewer's Avatar
jbrewer jbrewer is offline
$200 won't go very far in paying for a replacement tractor (at least a new one). If the Flex Disc joint fails, and allows the fan to find the frame and everything to bounce to a stop, I'm sure it DID make some serious barnyard noises.
That's not too bad a fix (just having gone through it on a 782D last year). A new driveshaft, new flex joints and a fan, and you're likely good for a while, if as you say , the engine is running well.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-04-2021, 08:36 AM
Inspect the couplers, both at the front and both at the rear.
I'll bet you have damage there as well.
I think you are in for surprise IF you price these parts at a Cub dealer.
One of the couplers is N/A and there are 2 of them.
Everything else still is.
Good luck!
Old 03-08-2021, 12:12 PM
eberner's Avatar
eberner eberner is offline
The drive shaft and couplers are available form "parts by Jeff" as mentioned by ol’George, just click the banner at the top and your off. The fan and flex disc joint can be purchased through CC Specialties. Looking at the prices its less that $200, more like $130 or so before shipping.
On a side note, I can attest to the superior quality of the Parts Jeff makes. He made me the same set up you likely need. They are much better that the factory parts they are replacing.
Old 03-08-2021, 04:18 PM
jcgbama jcgbama is offline
Ha, thanks for that. I think I added things up wrong or something because I was looking at those 2 links.
Just to confirm though(again, my ignorance on part names and such) but the couplers are the fabricated metal on each end of the drive shaft that the flex couplers bolt onto, right? Those definitely need to be replaced because both of them were sheared off at one of the bolts.
