Old 03-09-2021, 09:25 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Originally Posted by HudsonvilleHornet View Post
there are a couple relief valves with the buttons on them.
If they have buttons on them, they are manual release valves, not automatic. They shouldn't relieve hydro pressure unless the buttons are pressed down. You mention that they look stuck, perhaps they are pressed down slightly allowing for pressure to escape quicker than normal?
The best way to free them up is with some penetrating oil, then take some pliers and slowly rotate them around. The penetrating oil should slowly seep down in there and free up the buttons.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 03-10-2021, 09:36 AM
HudsonvilleHornet HudsonvilleHornet is offline
They're caked in dirt right now, I want to get it cleaned up a bit before pushing them to avoid potentially working grit in the bores. Been a little cold out for a car wash until just recently.
Old 03-11-2021, 06:49 AM
dale c. dale c. is offline
clean it up , use a small wire brush on the pins that stick up use air pressure to blow dirt away then spray with penetrant leave sit a while , before pushing them down , once you're sure they're free a little grease on the pins will help with rust
