Old 05-21-2021, 07:54 AM
Turbosilv03 Turbosilv03 is offline
Did you check spark on the no workie cylinder?
I.E. laying the plug on the head, connected to the plug wire and cranking it with the starter motor?
it should spark properly, if not, you have an electrical problem.
I did check spark. And it has good looking spark outside the cylinder. I'm gonna get some intake gaskets and replace those, see how it goes from there.
Old 05-21-2021, 07:56 AM
Originally Posted by Billy-O View Post
An intake gasket leak can do it.... Better than a valve issue. Report back after you fix it.
Kinda upset with myself over this, I sprayed carb cleaner all over the intake gaskets to rule them out when I started dicking around with this thing and nothing happened. It must have sealed with the caked on dirt and grime. I cleaned it better after I tested it, so whatever seal it had with the dirt and shit must have went away after cleaning
Old 05-21-2021, 09:11 AM
SGragg SGragg is offline
Inactive Member
Don't be upset with yourself (easy for me to say). A new set of intake gaskets is better than a more expensive problem. Right now, you're out of pocket a shiny, new coil and a set of gaskets. Not the end of the world.
If you've been getting the amount of rain we have, you won't be able to mow until after July 4th anyway...
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 05-21-2021, 02:39 PM
Got intake gaskets today. How handy is it that they come with a sticky side to put on the intake so you don't drop them?!
Went to take off the intake, started with the working side loosening all of the bolts. Worked to the dead side. Once I got to the dead side, I put my ratchet on the bolt head and low and behind they were backed out. I just got the mower last year so I've never had it apart like this.
I chased this problem for a while now, rebuilt the carb, replaced a coil, and spark plugs, compression check and all of the fixins lol. All for the intake bolts to be loose lmfao. Needless to say while it was apart I put in the new gaskets and boom. Runs like a top again!!!! Tha ks all for the insight. I was really at my wits end.
Old 05-21-2021, 03:43 PM
Now you have spare parts of known good quality for the future
