I just replaced a set on a xt1 with 54" fab. deck they were breaking /splitting from the end back into the blade 1-1 1/2" . I wouldn't want to be standing beside the mower when running . I put Oregon blades on so i'll see how they hold up
I didn't understand the question, nor the reason for the impatience.
After reading the original post a couple times, I think modcub72 is referring to the cutting edge being swept back on the Cub blades leaving less material to grind before getting into the wing. I never understood why they did that other than to reduce cost by saving metal.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
I believe the edges are angled back to give more of a shear cut.. That is just my guess. Damn.... I can't remember ever replacing the blades since getting the 125. These are IH blades with part# stamped on them. I've sharpen them two, maybe three, times a year and yes, it is almost time to replace.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I would think if one had the welding skills and right equipment, the leading edge could be built up with weld, cutting edge restored, and prolong the blade life.
Unfortunately I have neither the equipment nor skill to attempt it.
Ol' George, you always crack me up.
IHinIN, you're exactly right. R bedell, I've done that many times in the past. Ambushed, that was really funny and we're on the same page with do'n with what ya got. Ol' George now's the same mentality. CC sells them that way , so that they wear out a lot faster. I grind the blade in multiple steps on each end. Less than 90 degrees for each step. Sorry all for the confusion, I just wished I could show pictures. |
I just put a set of Gator blades on my 54" GT. I'll never go back to Cub blades.
