Old 08-09-2021, 08:28 AM
ejl6658 ejl6658 is offline
Does the rotor for the brake move when you press the forward or reverse pedal? The release lever not working and the brake pads not engaging the rotor need to be repaired before you dig into the rear differential. Your comments are making me feel your missing something simple.
Old 08-10-2021, 02:29 AM
Cookieone's Avatar
Cookieone Cookieone is offline
Originally Posted by Cookieone View Post
The driveshaft turns freely when the mower is running. If you push the pedal forward or reverse you can hear the pump pumping and hydraulic motor turning. But doesn’t even try to move. Except when it’s jacked up off the ground and then the wheels will move but can easily stop them with your hand. The release lever won’t move from its position. Which seems to be in the middle between engaged and disengaged. The brakes will not engage on the rotor either. So it’s not trying to stop the axle.
Well I did get to remove the transaxle this afternoon and by following the instructions manual I removed the pump and motor and the disc brake. I took out the 14 bolts that hold the left side on and haven’t got it to separate yet but didn’t get to spend anymore time on it either. Tomorrow I’ll go back over the procedure and make sure I haven’t missed anything. But so far the output shaft(the one that goes parallel above the axles) turns with the input shaft from the motor. And that’s where it stops. So something is definitely broke inside. The fluid doesn’t look very good either. Really dark and looked like a lot of metal grit. I don’t think the fluid or the filter has ever been changed. I’ll post some pics tomorrow when I get it pride apart and disassembled. I’ll probably make a YouTube video as well showing what has happened. Thanks again everyone for the help and encouragement.
1812 custom cat0 3point hitch, foot pedal, 2155 JI Case 470 shuttle speed.
Old 08-10-2021, 07:53 AM
Make sure you clean up the ends of the axle of any rust with some fine emery cloth or you may damage the axle seals and have a heck of a time getting that part of the axle thru the bearings.
Old 08-10-2021, 01:37 PM
Cookieone's Avatar
For some reason I can’t upload a pic right now. But the culprit is the left axle shaft at the spider gears is stripped out. So a new axle and bevel gear and should be up and mowing again.
Old 08-10-2021, 07:35 PM
Cookieone's Avatar
Once again thanks for everyone’s response and help. Y’all have saved me some bucks. I’ll post back when my parts come in and get it back on the yard!
Old 09-07-2021, 05:56 PM
Cookieone's Avatar
Well it’s been bout long enough and I’m still waiting on parts. An axle shaft for this 25 23 and lip seals for my 1812 for the hydro pump. They’re on back order from the factory and according to some parts distributors there’s no one that has any new ones in stock. Do any of you. Guys on here know where I can get a used axle for my 2523 or have a couple lip seals laying around? Just let me know I’ll send you a money order for part and shipping.
Old 09-07-2021, 07:19 PM
CubDieselFan's Avatar
Do you know the part number of the seals? Are you needing all the seals?
Old 09-07-2021, 07:41 PM
Double check the part number, but here is a axle shaft on eBay.
https://www.ebay.com/itm/14403744791...AAAOSweu1gnEaQ
Old 09-07-2021, 08:51 PM
Cookieone's Avatar
Hell yea man that’s it. Thanks I’ll get on that.
Old 09-07-2021, 08:53 PM
Cookieone's Avatar
I just need the 2 lip seals where the drive shaft enters and the rear where it exits. The company that ordered through has all the rest.
