Not currently, prior to recent events the PTO has responded to the switch like it should.
With the tractor turned off, mark where the actuator arm is and check to see if there is tension on the PTO belts. The belts should be loose with the engine off.
Does the deck engage when the tractor is started or do you have to pull the PTO switch?
Alright, I have checked a couple of items that you guys suggested.
1) If I pull the vacuum line off of the actuator (mower running/PTO engaged), the rod doesn't really move. Maybe the baffle isn't happy with my rebuild.. 2)The front belt is pretty loose I can slip the belt by hand, the rear belt is a little tighter (but I can't slip the belt.) Both belts appear to have a fair amount of deflection. |
If you pull the vacuum line off the plunger should come back out. Did you get the diaphragm back into the groove and not poke a hole in it. Do you think you got some rtv inside that is causing the plunger to stick and not to come back out. Only thing I can think of.
Is the PTO return spring item #17 on the parts diagram connected?
https://www.cubcadet.com/en_US/conte...0cdd997352cd/y |
Have you resolved your pto issue and what did you find?
