Old 10-19-2021, 03:40 PM
sorner's Avatar
sorner sorner is offline
Originally Posted by 05snopro440 View Post
Can you elaborate what the lift rod issue is?
Assuming all supers are the same, the lift arm is under the fender and not above the fender. I had to add an extension to the lift arm on the snow thrower like pictured because the lift arm wouldn’t clear the axle without it. EBFF6752-79D9-47B0-A9E6-BCCCB3382205.jpg
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 10-19-2021, 03:50 PM
05snopro440 05snopro440 is offline
Originally Posted by sorner View Post
Assuming all supers are the same, the lift arm is under the fender and not above the fender. I had to add an extension to the lift arm on the snow thrower like pictured because the lift arm wouldn’t clear the axle without it. Attachment 109291
No, my lift arm is above the fender.
1992 2182 with 48" deck, Kwik-Way loader, and QA42A Snow Thrower
2008 RZT 54
Old 10-19-2021, 04:16 PM
Posting complete and accurate information is imperative, and gets you the right answers.
6 replies, only one was responding my original question. The parts I need are the same for a QA42A or a QA42. You can split hairs if you like about me not identifying the implement right (I'm new to Cub Cadet), I'm just looking to answer to my original questions, which my original information was sufficient to answer.
2008 RZT 54
Old 10-19-2021, 05:59 PM
For anyone else looking, I found this thread regarding U-joints.
https://www.onlycubcadets.net/forum/...ead.php?t=7793
2008 RZT 54
Old 10-19-2021, 06:38 PM
sorner's Avatar
Ok. Mine is like this, so you might be fine as is. I don’t know. With mine the front axle is directly between the lift arm connections.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 10-19-2021, 06:49 PM
sorner's Avatar
I got away from the original questions because if you’ve not had the blower on that tractor, it’s not just plug n play. I rebuilt my QA42A last year but I acquired it in pieces and had to reassemble it. Most of the parts were already there except the bearings on the end of the auger, which are available at TSC. They’re a bearing sandwiched between two plates, and you can mix and match parts there. Just take the old one with you and match up what you need.
I don’t know much about the shaft or gear box. I do have an extra shaft with ujoints here somewhere that’s in good shape except it was painted over.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 10-19-2021, 07:51 PM
The Gear box uses std. bearings readily available and less expensive on Ebay.
The shafts are available from "jeff" at the top of the page.
Gears? well yer on your own there,as they have been NLA for years but pop up on ebay ocassionally.
Best to get a good used gear box most times, cost ways.
Have fun
Old 10-19-2021, 10:51 PM
Thanks for the info. The PO had it on the tractor and used it for many years to clear snow on the property I now own. I'll find out how it works once I get it put back together and on the tractor (and we get snow, which could be weeks away).
I found the auger bearings yesterday. We don't have TSC in Canada, but I went to my local farm store and they had what I needed.
The transfer shaft gear was rubbing on the tensioner bracket, I'll have another look at them. There was a ton of left to right movement in the transfer shaft, I'm wondering how to get that slack out.
2008 RZT 54
Old 10-19-2021, 11:47 PM
Have fun
Thanks for the tips. Looks like gears are available at CC Specialties but I shouldn't need them.
I opened up the gear box today. I need to clean it out, but everything seems tight with no slop and no shavings in there. What I thought was slop in the bearing looks like it was just a loose connection to the driveshaft. I'll have a better idea when I get a chance to clean the gearbox up.
2008 RZT 54
Old 10-19-2021, 11:48 PM
The auger bearings I got had the part number PF205-16, if that helps anyone else here's a link. https://www.amazon.ca/SBPF205-16-Fla.../dp/B0056JH3KU
2008 RZT 54
