Old 10-23-2021, 02:58 PM
TheSaturnV's Avatar
Hydros on Cub Cadets have been in service since 1966. Some in almost constant use, others left outdoors for decades, only to be pressed back into service again by we enthusiasts. Rarely do we come across an actual hydro failure.
I'd say the IH hydrostatic drive has more than earned its stripes.
To the OP, I prefer hydros for most every job, but if I need some good old slow speed grunt, I dust off my Sears Suburban.
Old 10-25-2021, 09:05 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Those Sunstrand hydros DO seem to be virtually indestructible .
My observation about the hydro, is that while the hydraulics are strong, the linkage doesn't seem to age well.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-25-2021, 09:43 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
The way I see it, both have their strong points and their weak points. Gear drives are good at putting power right to the wheels, however lack speed variability, and the driveline tends to have weak points (roll pins, clutch wear, etc). Hydros are great with infinite speed ranges and a lot less complicated driveline, however don't put power to the wheels as efficiently as a gear drive, and the control linkage wears out.
As for repair, Honestly the way I see it, neither a hydro nor a gear drive transaxle should really need to be repaired as long as you use them and maintain them correctly.
Lets all agree to disagree, and keep this thread from becoming an argument please
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 10-26-2021, 01:48 PM
IHCubCadet147's Avatar
I like both, but I think if I could only have one tractor to do all my work it would be a hydro, probably a 147. My 126 is my only gear drive Cub, just because that’s the only one I found the right deal on. For mowing, I think a hydro is quicker and easier, but I like to use the 126 once in a while. Hydro for spreading gravel also. Plowing snow and pretty much any other work I do either one is fine. For garden work, plowing, tilling, etc. I think I would choose a gear, but I don’t do any of that stuff.
Old 10-26-2021, 02:19 PM
jbrewer's Avatar
This just proves it's good to have several of each!!!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 10-27-2021, 08:31 PM
Jim in SC's Avatar
Jim in SC Jim in SC is offline
Gear drive. I guess the letter series Farmalls might have influenced me. I can see how a hydro would be better for mowing though...
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106
Old 10-28-2021, 12:12 AM
I like my Farmalls also,
my 400 TLB, and 806 Wf are my favorites.
Only surpassed by my 70 and 730 2 Cylinder John Deer's.
