Old 11-30-2021, 05:49 PM
finsruskw finsruskw is online now
What did I say??
Old 12-01-2021, 02:26 PM
05snopro440 05snopro440 is offline
What did I say??
I wasn't responding to you, as evidenced by who I quoted. I was simply agreeing with your statements. I didn't realize nobody else could comment. They should put that in the site rules.
1992 2182 with 48" deck, Kwik-Way loader, and QA42A Snow Thrower
2008 RZT 54
Old 12-02-2021, 01:10 PM
Best to ignore some of the unwritten rules that appear. I appreciated the
confirmation on the bends and hopefully the original poster has some
better idea on his 42A. Chime in anytime with whatever your thinking.
Ken
Old 12-02-2021, 02:16 PM
Ken
Thanks Ken for the encouragement. I've seen some rather irritating unwritten rules appear so far, so I quite appreciate it.
2008 RZT 54
Old 12-02-2021, 05:02 PM
Unwritten rules ???
Old 12-23-2021, 02:04 AM
Wntsom4 Wntsom4 is offline
For years all my dad had on ours was a length of chain and two small clevis on each end.
I purchased a lift rod this year want to try it out. Think it was 28” for my 1250
Old 12-23-2021, 02:12 PM
Farmall450's Avatar
There were different lengths of lift rods. I have a QA42A for my 2182 and I don't know if the rod length is the same. In fact, the PO gave me two different length lift rods.
It's literally a rod with a 90° bend on each end, and a hole for a cotter pin. I can measure the diameter if it helps.
As far as length, maybe this will help: http://www.xtrememotorworks.com/Snowblower%20Parts.html
Definitely not the same, as a 2182 should have a 451/551 2x blower.
Old 12-23-2021, 02:15 PM
Farmall450's Avatar
Chain is nice in that it will float, always, and if you hit into a hill or whatever it can float up more. Bad news is it'll hit something else going up, vs being limited by the lift rod. I am contemplating adjusting my #450 lift rod to get some more height (lowered on flat/level surface is still at 3.5 on the height indicator), but want to alleviate other issues from arising.
It's pretty snug on my 1811 with the lift linkage. Fortunately they did a pretty dang good job designing them where nothing should interfere with the grill/front casting for a while (torsion rod is close, but doesn't move out of it's axis). I did pull the tunnel to clean/change trans filter and verified that the hydraulic lift was in the float pin).
I could probably rebush everything and gain a marginal amount of lift, too.
Old 12-27-2021, 10:27 AM
mortten mortten is offline
Jeff in PA, a member here, makes adjustable lift rods.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 12-29-2021, 02:09 PM
Should have? They were available, sure, but you can mount a QA42A to a 2182 as well. As I said in the comment you responded to, mine is a QA42A, NOT the 2-stage 451/551.
2008 RZT 54
