Old 01-02-2022, 04:07 PM
CubbyRI CubbyRI is offline
Ok I fixed it at least for now.
1) loosen the cable pinch screw at the governor
2) remove air cleaner and loosen the cable attachment screw under there
3) remove the two throttle unit mounting screws on side of tower (backing nuts are inside)
4) turn the throttle and push the handle thru the slot to remove the whole thing
5) the outer cable unscrews from the throttle unit
6) pull out the inner cable with vice grips, if stuck, soak w pb blaster
7) run 320 sandpaper up and down the cable to remove scale and corrosion
8) make sure inner cable ends are bent perfectly straight (use small vice grips)
9) coat with anti-sieze and push thru, pull all way through, recoat, repeat several times
In my case since the end had broken off, I cut that much off the outer cable to match using Klein's lineman dykes
Reassemble and wait for the next time in a year or two!
I will try to source a stainless inner cable before then!
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 01-08-2022, 10:48 AM
jbrewer's Avatar
jbrewer jbrewer is offline
To free up a frozen one, shoot as much PB down the thing as possible. Then flex the outside back and forth along the length of the cable. The housing is springy so you can move it back and forth to un-freeze it.
I've never had this NOT work.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-09-2022, 08:21 AM
Workingstiff Workingstiff is offline
This^^^^
Are the 100's a jacketed cable? I like the idea posted earlier about covering with hose. Possibly some small ID fuel line once cleaned up and broke free. Shoot a little love yearly as a maintenance item, to keep things moving freely.
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 01-09-2022, 12:22 PM
These older cubs at least are just wire-winded outside with a stiff wire inner. Jbrewer method opens the cracks and lets the lube soak in. I was looking for something more durable when mentioning covering the cable because otherwise water soaks in on that lower curve that hangs down exposed between the tower and the carb.
In my case see above, I think the sanding the inner cable and applying anti-sieze may help.
That said, I realize now that the cub should not just be left exposed anyway so I will make a breathable rain cover for it. Has to be breathable because a tarp will just trap moisture and make all of the tractor rust even worse. But a tarp open at the ends would go a long way...
Old 01-10-2022, 11:03 AM
charlie105's Avatar
charlie105 charlie105 is offline
Default Frozen cable
Hey Rhodey ! Check this out. Google; Motorcycle cable lubrication tool. Would have to use it when it’s thawed out. Wet is ok. Only have to disconnect one end of the cable, preferably the higher end. I use PJ motorcycle chain lubricant. For me it has been good for several seasons. Good Luck! Steve .
