It's pretty cool you got yours from RF Houtz -- is there a hole drilled in the sidepanel to check the oil? My deck has the Houtz sticker but I'm not sure if the tractor is from there. Mine is a 1992.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
I am about 30 Miles southeast of You In Wayne, IL. I Use to live In Elburn till the wife wanted to Move to Wayne . I want to move Back to Elburn Myself
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force |
I think This Place https://www.ihccw.com/ Might Have 1 or 2 In again. That's where I bought one In August 2021, But You Might want to Go with this http://www.xtrememotorworks.com/Weig...20Bumpers.html Instead, Then You can put suitcase weights On the Tractor. He also builds a rear weight bracket as well. But because I have a 3 point. I won't bother with the rear weight bracket as you have to take off the 3point Hitch plate to use it and that can be a royal PIA because the Bolt Into the Transmission case actually go into the center Case and You have to reseal the bolts each time with something like this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 so I Just added a receiver Hitch and Use a Sleeve Hitch Insert from heavy Hitch with a 4 suitcase sleeve Hitch Mount weight bracket from Johnny Products. Next Fall I may add a Bercomac Cab to my 2182. If I use the 450 blower next year. Though I may just go with a rear Blade on the 2182 next winter As I have a Deere Blower for My JD X748 anyway. I would love to find a Haban front Blade for the 2182 But there hard to find around where I live
The original MTD front bumper is part number 190-398-100. As stated above, this place says they have two in stock..
https://www.ihccw.com/index.php?rout...roduct_id=1049 I have made two of them for my tractors using the later 190-298-100 bumper designed for a 2000 series tractor. The face bar portion is identical. I fabbed up the mounting brackets using an original as a template..
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Update on the tractor. I put a new seat on it yesterday. I have a new air filter, spark plugs, and fuel filter sitting here. Oil looks good, but I'm going to change it anyway so I know what's in it. Hoping to get all that done this weekend sometime and see how it's running after that. The idle seems a bit low to me, so I'd like to bump that up some as well.
I also need to go over it and grease any fittings. I think I'm going to go ahead and get the deck off as well and get that into the shop to start looking it over. I'd like to paint it back to the original yellow as well. I may throw the blower on just for kicks to see if it works properly, though I don't have plans to need it this season, my other tractor has a blade on it already anyway.
YouTube Channel - Outdoor Power and Tractors |
1. Ralph Helm Elgin after he took over Elburn a Driver For Helm Hit somebody and Killed a Person so They closed the Elburn Location Because he was being sued and I think Last year closed the Chrystal Lake Location and I Noticed Ralph Now has other Partners with Him at his Only Location 2. Carol stream Lawn & power 3. RF Houtz In Elburn There was another for a Little while, But That was Only Between 2011 and 2017 Bad customer service customers even had to use the Dupage country Sheriff to get Machines Back when they closed. I don't Know Wasco could Have sold Cub Cadet at One time With Houtz Closed as a full Line dealer since 2016 I use Carol Stream Law & Power Wife and I Bought a 2017 XT2 GX54D for a friend from Helm, Carol stream stopped selling Cub for a year or so didn't realize they were back selling it again when we Bought the XT2 GX54 otherwise we would have bought from them. Big Mistake, buying from Helm. 1st snow Blade for the GX54 D Lasted less than 1 winter season. Helm claimed our friend used it commercially, so MTD wouldn't cover it under warranty. Then I went there for Transmission fluid Later On after I Bought My 2018 Cub Cadet XT3 GSX(bought from Dekane equipment) and the Part's Manager proceeded to argue with Me On doing a Transmission oil change that it didn't need it and I haven't gone back since. We ordered a Cub Cadet SX 54 Z Force from Carol Stream last October, should be In sometime in April. I just finally got sick of Mowing with a convention tractor, but I don't like lap Barn zero turns either, so bought a SX with steering wheel. Had been Mowing with the XT3GSX since June 2018 and the way I mow the property, a Zero turn is just better suited for it. The XT3 will be used for Bercomac Tiller work & Bercomac Rotary Broom work. . I have 6 Cub Cadet Garden tractor 5 Deere Garden tractor Plus a Deere compact and 3 other Garden tractors of different bands so a Little Garden tractor Crazy 5 cub cadets at the House My Cub 70 and a Cub 60 Rear engine rider our In storage down In Naperville at a Car condo that My Brother's and I own.
Don't forget the Farm & Fleets are full service cub dealers. Terry is really good in Woodstock. Elgin would be closer to you. I heard Helm was closing CL due to no product, but it would make sense they're saying that if there are...others issues. Sorry to hear about your experience there.
Max's Family Farm or whats left of it is at Rt 23 & River road On the North East Corner He Had about forty John Deere 2 cylinders In that Green Barn Up there just before the Marengo Ridge Conservation Area If I Just dealt with Ralph it was No Problem But his service Manager at Elgin I just want to throttle him Well There is Johnson Tractor Up In Harvard I use to use them when they were AA Anderson's Carol stream outdoor Power is 40 plus years old. Current Owner Has owned it over 30 years Farm & fleet use to Carry Up to the 2500 series at One time But Now they are Limited to the XT2 series In Lawn & Garden XT3 is still the Traditional Dealer and You could not order the 3000 series from them either when That was on the Market. So they are a Little Limited
