Old 03-09-2022, 12:28 PM
RLause's Avatar
RLause RLause is offline
Claims to be super stuff
https://www.fluid-film.com/agriculture-applications/
Richard
Old 03-09-2022, 12:32 PM
Thin grass in sandy soil keeps my deck shiny!!
Old 03-09-2022, 02:04 PM
Farmall450's Avatar
Originally Posted by Cubcadet_107 View Post
I cannot remember the exact information, but I have read on another forum about people having good luck with oiling the underside of their decks a specific way. IIRR they removed the deck and recoated it every year or so. Prevented rust and kept grass from sticking to the deck, but not a permanent fix.
I personally doubt there is ever going to be a permanent fix, but you never know
Arnold sells a non-stick spray for decks. Fancy pam?
https://www.farmandfleet.com/product...ick-spray.html
Old 03-09-2022, 04:05 PM
zcub22 zcub22 is offline
This is for a neighbor who is very lazy about maintenance. I'm thinking bed liner would last for the season and prevent more rust after I've cleaned and painted.
Old 03-09-2022, 08:21 PM
Workingstiff Workingstiff is offline
Fluid film has been out a for a number of years. I got a free can when they were new to the scene.
Never have used it on the deck though.
I wirewheel and do quickie WHITE paint job every season on every mower. Nothing lasts. I use white so i can easily see where the build up is.
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 03-11-2022, 07:52 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Fluid Film is the best stuff to protect my daily drivers from the effects of road salt. I'm sure it would work well on decks.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 03-14-2022, 07:22 PM
twoton twoton is offline
When I first get a deck I coat the underside with POR 15, followed by a couple of coats of graphite coating. Then, once a year or so I wire wheel them clean and re apply the graphite.
Old 03-16-2022, 10:19 PM
MBY852's Avatar
MBY852 MBY852 is offline
I picked up a can of EZ-Slide Graphite-based coating from TSC. I sandblasted the bottom and primered it and so I heard this stuff was pretty good so I'll give it a shot.
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 03-28-2022, 03:27 PM
Clodhopper Clodhopper is offline
The only place my 50C ISN'T rusty is on the underside...
Old 03-28-2022, 08:08 PM
mortten mortten is offline
EZ Slide didn’t hold up well on mine.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
