Old 03-28-2022, 12:27 PM
Farmall450's Avatar
Originally Posted by 1711Cub View Post
The 2165 was produced '94-'99.
Per the owners manual: Use Cub Cadet "Drive System Oil" part number 737-3055 or a 20W50 oil that meets API service class SG/CD, which is an antiquated SG from when the tractor was new. The special drive system oil's part number is now currently 737-3120. It is very expensive at $17 a quart!
At $65/gallon it's actually still cheaper than actual hytran:
https://www.farmandfleet.com/product...trans-oil.html
I run the F&F imitation IH HyTran, though:
https://www.farmandfleet.com/product...-tractors.html
Don't forget an OEM filter (even on sale!):
https://www.farmandfleet.com/product...il-filter.html
Old 03-30-2022, 10:56 PM
Ducksrus Ducksrus is offline
Thanks for all the info
