I will give this a try. I just placed a order for 1, and if it works, will order some more to keep in hand. Thanks for the info.
You might put a drop of red Loctite on it to help hold it in.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
See if you can un-screw the zerk, then you can drive in the "drive" half, and re-install zerk. Make sure you have the hole for the zerk pointed correctly before driving in. |
the most part is the clearance to tap it down with a small hammer or something , i've got a tool that works for strait or 65% fittings but all are made for wide open space . but that 2 piece is a nice idea in case it fails again i just replace the top part.
I'm surprise for as long as XT1 has been out that no one has had this issue and DIY fix it ?? or just bought a new rim for $80. just for the grease fitting ??
They must be open bearings to receive grease from the inside like that.
Pull them and repack them like we always used to have to do in the past. Not really familiar with the newer ones though so they may just be bushings and not bearings per se?? |
