Old 05-06-2022, 10:27 PM
sorner's Avatar
sorner sorner is offline
Originally Posted by Radioguy41 View Post
Hmmm, I think I found the clutch problem. You don't think the bolts instead of pins, the bent plate, the broken discs, the wornout pivot pin, and the off-center throwout bearing might have anything to do with it?
Wow, that's a really bad repair job... what's keeping that bolt from coming out and putting your eye out?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 05-07-2022, 06:42 AM
I have a like new clutch disk you can have for $20.00 plus the shipping. I'll get some pics a little later.
Old 05-07-2022, 07:55 AM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
Thanks, looking forward to the pics. Much appreciated.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 05-07-2022, 11:39 AM
Pics of the clutch disk
Old 05-07-2022, 04:25 PM
Radioguy41's Avatar
Looks like the 6.5" version all right. Thanks very much, I'll message you my email address and you can send me the total with shipping and how you prefer payment. Again, much appreciated. Now I have to see if there's any chance of saving the pin disc.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 05-07-2022, 04:51 PM
Looks like the "Drive studs" are still available. Cub as expected is stupid expensive, the want $150 for 3 of them. This is a google search
https://www.google.com/search?channe...cadet+911-3043
Screen shot of the Cub price. I bet JeffinPA could whip up a few with no problem.
Old 05-07-2022, 05:27 PM
Radioguy41's Avatar
Yeah, I saw those dealer prices. Kind of crazy. I'm sure I'll be contacting Jeff, and here's within driving distance!
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 05-08-2022, 05:57 PM
Radioguy41's Avatar
This beauty has a slight modification to the clutch pedal return spring connection and just a bit of wear on the pivot pin. What's strange is someone went to all the trouble to replace the clutch release lever but not the pin.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 05-08-2022, 06:05 PM
Radioguy41's Avatar
Next question, how do you get the driveshaft out? It seems to have a pilot at both ends and someone stuffed 2 rag joints in the back end so it is real tight. I have everything disconnected and it's not moving. What's the secret? Do I have to knock out the roll pins?
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 05-08-2022, 07:31 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I slide the engine forward. 6 bolts and the engine plate will slide forward plenty to get the shaft out. You will need to pop the spirol pin out to get the shaft out unless you want to remove the rag joint bolts.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
