![]() Quote:
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
![]() Quote:
The point would be to use the same Brinley-style attachments but on the 982. I agree with their decision then, but since Cat 0 is a niche thing mostly of the past, I'd rather just share sleeve hitch attachments. ![]()
![]() Quote:
But Cat 0 isn't as dead as It use to be https://www.tuff-bilt.com/ ( they Never stopped Using it On this tractor https://www.motoalliance.com/all-pro...t-0-implements
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force |
![]() Quote:
![]() Quote:
And This Place still Make some 2000RPM PTO Implements https://befco.com/ That would work On Your 984
![]() Quote:
That would Probably work But since I have Both Cat 1 & Cat 0 arms I haven't tried it
![]() Quote:
Online I don't see a 1 --> 0 one from Farm & Fleet, but TSC has them cheap. Might be a good route to go if he can't find the original ones, but I also have a IH 284 w/ 3 point ![]() https://www.tractorsupply.com/tsc/pr...ft-arm-bushing
You Can never Have to Many 3point Hitches
All My Garden tractor Have either a sleeve Hitch or 3 Point Hitch Cub Cadet: Original IH 3point 70 IH 3point 106 IH 3point 1450 IH 3point 2182 Cat 0 & Limited Cat 1 3point Hitch XT3GSX OEM sleeve Hitch with Johnny Products electric Lift Kit I Brinly sleeve Hitch adapter for all the IH 3points Piecing together a Cat 0 for the 3000 series Ingersoll: 3016PS Had a sleeve Hitch for it at one time John Deere: 110 Round fender JD Integral Hitch 112 Square fender JD Integral Hitch 140H3 Cat 0 3 point JD Integral Hitch GX335 Johnny Products Universal electric Lift Sleeve Hitch X748 Limited Cat 1 3point Hitch 2025R Limited Cat 1 3point Hitch Wheel Horse: 416H Clevis Hitch(there Name for a sleeve Hitch) White: GT2055 Cat 0 3point Hitch I have 3 Simplicity One Point Hitches(What Simplicity Calls there sleeve Hitch) A One Point for the Sovereign series( sold the 7016 Sovereign) Two One Points for the Prestige series One for a Tractor with Suspension and One without Suspension. If I buy a Garden tractor I want to be able to use it, in the Garden even if It Never Get dirty anymore ![]()
