I've bought both the Stens and Cub Cadet brand caps. They are identical other than the wrappers and the Cub cap was almost double the price. They do differ from the original slightly, but are far better than a brown lens and loose needle.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Do they make a diesel version or am I just going to have to remember that??!
Diesel fuel cap/gauge is 751-3044.
I wonder if the 882/782D was the first CC garden tractor with a rear gas tank?
Obviously they liked the idea, since Cyclops, Series K, and LTX/GTX series all stayed that way until the XT series.
I believe that is correct. They also used a similar tank in the lawn tractors from the late 80's and up to. In fact they use the same fuel gauge cap as the diesels.
Got the carb and intake back on, as well as everything else buttoned up and the mouse nests blown out. Runs pretty good and drives great.
I do need to find 1 of those plastic clip/locks for the throttle arm going to the carb, and one clamp for the choke cable (which I should have somewhere).
Kohler 25 158 11-S Throttle Linkage Bushing
Kohler 235778-S Choke cable clamp
Are those Stens ones long enough to go to the bottom of the tank on a 782? BTW nice work on the 782, does that one have the fuel shutoff on the carb?
Up to 534 and counting... I give up updating my profile! |
No carb fuel shutoff, and yes it's long enough for both machines as well as the 1811. They're all Kulch OEM.
