OEM did fine. I’m back in business.
Not surprising. Glad it worked out.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
I'd be interested in seeing the threads measured on the WIX.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I have a thread pitch gauge, but I didn’t think about using it until later on; I was in a bind because the tractor was unexpectedly down. I drained the hydro oil first instead of changing the filter first because I assumed the filter would work. Only reason I went through all of this is because the diff cover leaked. It wasn’t true and flat like my cylinder head now so I just a high quality RTV like what I’d use on a GM rear end. No leaks and its doing fine.
