Closed Thread
Old 06-12-2022, 05:45 PM
Farmall450's Avatar
Originally Posted by Cadmandu View Post
R they for forward and reverse
That's why there are two.
Old 06-15-2022, 08:27 AM
Cadmandu Cadmandu is offline
anybody have a good source for the gasket required 1988 2072 diff
Old 06-15-2022, 08:55 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Aftermarket $14 inc shipping:
https://www.ebay.com/itm/15458168254...cAAOSwjmheWqby
Original:
$15.80 plus $10 shipping:
https://ccspecialties.org/hydroparts_holddowns.html
921-3015/721-3015
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-15-2022, 09:16 AM
Thanks a lot. I'm going to Tractor Supply soon, to get that cheaper fluid. If you break those valves loose to help drain the fluid can you take them out and clean them. Should I replace the O rings?
Old 06-15-2022, 09:33 AM
1711Cub's Avatar
Lightbulb
If you are removing them, no need to clean them internally. By all means, keep them clean when out, and clean them externally. Before removal, blow out the areas around them with compressed air. No need to replace the o-rings, as they are specific to these units, but are available online.
Old 06-15-2022, 11:07 AM
Thanks for all the great help. I bought a new carb and fuel pump and filter. I'm removing the fuel tank so I drain and clean. I'm going to remove my 60 in Haban so I can sharpen the blades and paint it. This is my first time. I now have a garage so I can slide it out. Do you pull it out from the left side? How many connections do I have to deal with. I have a swing set frame and a chain fall. Do you think that would pick up?
Old 06-16-2022, 07:48 AM
I'm having trouble getting the travlers universal tractor fluid. All the TSC stores are out. A y suggestions
Old 06-16-2022, 08:24 AM
1711Cub's Avatar
Exclamation
Go to a local Case/IH dealer and get the right stuff. There's a reason it's more money. It's 100% zinc free, and can hold up to 1% of it's volume in moisture, which is advantageous with a system that does not get warm enough to burn the moisture out of the oil during normal operation.
I paid $28 with tax inc. a gallon of it two weeks ago.
Old 06-16-2022, 06:04 PM
They said it has been on back order for months.
Old 06-16-2022, 06:36 PM
1711Cub's Avatar
Question
Define they?
Closed Thread
