Old 06-12-2022, 07:04 PM
Farmall450's Avatar
Originally Posted by 1004ron View Post
The grass is fertilized and seeing good rains and loads of sunshine - I cut once a week with the mower set at #3 - the grass is about 5" at the time I cut.
Yes, WOT.
I'm using the mulching cover.
Can't get a good photo.
Cutting higher/more frequently might help. Plus it's a lot better for the grass to not knock off more than 1/3 of it at a time.
Old 06-12-2022, 08:09 PM
Ozcub's Avatar
Ozcub Ozcub is offline
It will not change the cut , but the motor should be running at 3600rpm approx
Oz
Old 06-12-2022, 09:08 PM
1004ron 1004ron is offline
Oz
Thanks.
When I got the hr/tach and checked it and found it at 1800 for idle and 3200 for WOT, and assumed that's correct, but you post prompted me to Google what this Briggs & Stratton engine should be and it comes up with 3600.
As you say, it may not resolve the issue, but should get it closer to optimal.
I found a Youtube video on how to adjust it, and just need to buy myself a curved long nose pliers.
Old 06-12-2022, 09:56 PM
Take it to the dealer and let them fix it the right way. Messing with the linkage may void the warranty
Old 06-14-2022, 07:14 AM
bugeye bugeye is offline
Smile
A quick search yields a new 30H has a "3-year/120-hour limited residential warranty"
Back to the dealer for proper set up.
As the grass needs regular attention, get a dealer commitment for quick turn around service
Enjoy your new mower
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
