Old 09-04-2022, 01:56 PM
Jonw1978 Jonw1978 is offline
I'm in the market for new rear tires. Main purpose for my 1512 is plowing in the winter time. Are these tires superior that just turf tires? Do you still need to put chains on them?
Old 09-05-2022, 03:58 PM
Farmall450's Avatar
I'm sure they're better than normal turfs, but still would benefit from weight + chains (if you're not going on blacktop/concrete).
Old 09-06-2022, 09:23 AM
Sergeant's Avatar
Sergeant Sergeant is offline
I recommend wheel weights more than likely won't need chains if Using these https://www.millertire.com/23x10-50-...ac-4-ply-tire/ or this Brand https://www.millertire.com/23x10-50-...sle-all-trail/ Like I said early I have yet to even use the diff/lock On the Tractors that have them and they work Great off pavement as well
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force
