Old 10-23-2022, 06:23 AM
The Ruegg kit is an improved copy of the original SGT hitch.
The Xtreme is a copy of the GT hitch with a longer lift bar. Rear PTO was never an option on a GT so it doesn't have the hole & shield for the PTO.
Old 10-23-2022, 10:16 AM
Rex B Rex B is offline
The Ruegg setup looks a LOT different from the OE setup. I have not seen a good photo of it though.
But Ruegg no longer makes the CC kits?
Old 10-23-2022, 10:46 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
I believe this is a Ruegg setup
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 10-23-2022, 12:46 PM
Sergeant's Avatar
Sergeant Sergeant is offline
Unless You Have a rear PTO No need to Bother with a Ruegg Kit(which My Understanding Bill No Longer Produces) and In today's day and age It Can be really hard to find 2000 RPM PTO equipment Befco does still make 2000RPM tillers The Market is so small Now for 2000RPM 3 Point equipment. I adapted The Xtreme Cat 0 he Make for the Super Garden tractors to Be a Limited Cat 1 3point thanks to some Help from Bill Ruegg. Have a Cat 1 3point Blade On it right now for winter and I can switch it right back to a Cat 0 if needed .
If You want to find a Garden tractor today for used with PTO Power equipment Look for a Used Simplicity Legacy XL or a Used Deere from the List Below
425
445
455
X465
X475
X485
X495
X575
X585
X595
X700
X720
X724
X729
X740
X744
X748
X749
X710
X730
X734
X738
X739
X750
X754
X758
These Model You Can still get new from John Deere with a 540RPM rear PTO
X730
X734
X738
X739
X750
X754
X758
Its actually easier to Find an IH Number 2 or 2B or MTD 38inch tiller to adapt to a Standard Cub Cadet Garden tractor Than it can be to find 2000RPM 3 point Mounted equipment in Cat 0 to work On the Old Cub Cadet Supers. Oaks Been Pretty Lucky finding 2000RPM PTO equipment
Most of the time when You find a 2000RPM rear PTO for the Supers It come with a complete Cat 0 3point Hitch There In the $1,000 Plus Price Range right now. I would say go with the Xtreme Modified Cat 0 3 point for Now You Just remove 6 Bolts and 2 Pins and 1 Lift arm To change out the Xtreme for and OEM super Garden tractor 3 point Hitch when You find One. That way You Can use the Super for Non Powered PTO equipment Until You find a rear PTO
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
