Old 06-23-2022, 09:24 PM
So it wont pop off with starting fluid?
Up to 534 and counting...
Old 06-24-2022, 12:33 AM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Spark but not even an attempt to cough to life would seem to suggest timing or something catastrophically wrong with the valvetrain. I would lean much towards the former, especially if "everything" has been replaced.
Old 06-24-2022, 06:36 AM
Low compression will cause that symptom also.
Old 06-24-2022, 07:05 AM
finsruskw finsruskw is online now
Remove the plug and place your finger over the hole and crank.
If the valves are operating properly, you should feel compression at this point.
I would not use starting fluid as it will wash down the cylinder walls.
A small shot of light oil should give enough lube to increase compression in a dry cylinder.
This, and I would opt for a small shot of carb cleaner into the carb.
If you have compression, spark and fuel, and the points are adjusted and timing is on, it will run.
Old 06-24-2022, 07:52 AM
Here ya go. To have a successful ignition, the Holy Triangle must be met.
