Old 09-06-2022, 08:46 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Well, here's an update on the 70. I decided to go ahead with the paint idea I mentioned in my previous post. I started with teardown:
The engine was not painted, that will be a project for a later date.
The frame as far as I tore it down
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 09-06-2022, 09:03 PM
Didnt take pictures until after new paint was applied, but just about all the old paint was removed from the machine, and then a coat of primer was applied. I do not have the skills nor tools for a proper paint setup so this was all done via spray paint, but i wanted to at least get the paint prep done right and strip everything down so the results might look half decent.
The hood, seat, and wheels received the correct Cub Cadet white.
while anything that was yellow from factory was painted my color of choice. IIRC its Rustoleum "French Lilac". Apparently i didnt take pictures of the frame until after I reattached the wheels either.
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 09-06-2022, 09:09 PM
Reassembly went pretty well. I dropped the engine back in it and assembled all the controls so I could do a test run. This included the first new decal, the dash decal.
Quick video of the test run: https://www.youtube.com/watch?v=DY3t5ss_ym8
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 09-06-2022, 09:28 PM
And finally, finishing reassembly and the final touches. Not too much to note here. The seat was the final piece to be installed. And if the orange gas tank bothered you, I did end up repainting it because it bothered me also.
And well, here it is, nearly done and all back together.
For what it is everything came out pretty well. There's a couple small spots I need to touch up from during reassembly. That's why the covering is still over the tires. Purple is an odd color choice, but since this machine has a history of strange paint jobs I figured I would try to continue that but do a little better job than the previous one (it was previously brush painted). The color I think actually looks quite nice alongside the CC white. Its far from perfect, but I'm pretty happy with it.
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 09-07-2022, 09:26 PM
Tom Dowling Tom Dowling is offline
It actually looks pretty nice with an emphasis on "pretty". Surprisingly pleasant also, nice work.
