Old 10-03-2022, 11:07 PM
Wild Bill's Avatar
Wild Bill Wild Bill is offline
There are several things you can check, trying to find the cause of the vibration.
Check the tightness of the:
Frame to transaxle bolts
Frame to nose/grill bolts.
Fender pan/foot rest to frame bolts.
Any of those being loose can send vibrations into the frame.
Did you check for a driveshaft spiral pin being 1/2 way sheared, or loose bolts at the flex couplings?
Take the spark plugs out, and take the plug wires off. Then turn the driveshaft connector hub on the back of the engine of Hold your thumb over the spark plug holes while manually turning the crankshaft.. If everything in that cylinder is OK-you will have air forcing it's way out of the spark plug hole as the piston comes up the bore. If you have a broken rod/valve spring-you will not have air pushing up on your thumb.
Original OCC Super Mod....and former OCC Co-Admin.
I was hacked........
Old 10-04-2022, 05:10 PM
beancent beancent is offline
Was able to remove one of the heads and found the piston was not moving while turning the crank shaft so connecting rod must have broke. Would any of you guys even attempt to replace the connecting rod or is this engine not worth saving. I'm not a stranger to engine swaps as I have done them on cars and old bobcats.
Old 10-04-2022, 06:51 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
This same thing happened to the KT17 in my 682. I opted to replace it with a Magnum 18. A lot of guys go with the Kohler Command engines since they are still available new, and are proven.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 10-04-2022, 09:54 PM
If it is the original KT17 series 1, remove it and keep it for a few parts, like the Carb, maybe some bolts/nuts, sheet metal covers.
And if it was me, Id go with the better and later Series II or better yet Magnum M-18.
But they are getting scarce, so a lot of ppl are going to the newer OHV valve engines as mentioned.
The Series 1 just isn't worth fixing IF one could even find parts.
And most times they destroy the block, break the camshaft, among other internal destruction.
As much as I like the opposed twins, the series 1 with splash oiled connecting rod design was a mistake that never should have happened.
It dam near bankrupted Kohler, back in the day.
Old 10-04-2022, 10:29 PM
Mine is a KT17 series ll. I believe that the magnum 18 connecting rod, Pistons and valves are a direct replacement.
Old 10-04-2022, 11:27 PM
SS5150's Avatar
SS5150 SS5150 is offline
I think that they are, but aren't they more or less obsolete?
If it's a good tractor for you it's worth the effort to do the Command swap.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 10-05-2022, 06:51 AM
Was looking at the isavetractors site and they are listing those parts.
Old 10-05-2022, 08:31 AM
1711Cub's Avatar
Lightbulb
If you are going to save the KT17 S2, replace the original brittle governor gear. Use either an original cast iron hear from an older single cylinder K series engine, or a new and improved nylon part from Kohler.
