Old 10-23-2022, 11:43 PM
backswampcub backswampcub is offline
Here is the dash looks like it had no choke. I assume this is the seat it left the factory with as it does not have factory Drain hole. Someone did punch three holes in it with a nail or punch to drain.
Old 10-24-2022, 10:57 AM
Must been a pull start as the choke was on the motor, as for the axles, the early ones were thinner in thickness then they made them thicker after there were issues of them breaking.
Up to 534 and counting...
Old 10-25-2022, 12:47 AM
I appreciate every ones help with this. I will post some more pictures with questions as I go along. I am going to pull what parts I need from my 4 digit cub that was in the restoration que. I will then try and track down parts later to finish it. It has the correct rear rims and a Motor. I will need to find all the pull start stuff to go on the motor as the 4 digit is set up as an electric start. I should have my new compressor installed this week which will allow me to start sand blasting. I have been using wire wheels and such for too long and it was time to upgrade some things.
