Check your reverse and seat switch. Those are the 2 that must be closed for the relay to stay energized.
Heh. -- Those were bypassed years ago by a previous owner.
Do you have a schematic for you tractor? You will need to check your reverse relay.
Looks like the switch or the PTO clutch. It want's to blow the in-line main fuse if I try and flip the switch up and hold it, so the clutch was working. Would be nice to simply bypass that switch for a simple on/off since the rest of the safety stuff is long gone.
Thoughts? ![]() |
I just wanted to say THANK YOU to Oak and the others who pitched in and provided much-needed information to get my seals replaced. It took a second attempt to see what I messed up originally, but I've been mowing leak-free a handful of times this spring and the steering is working great. Even seems to have a bit less 'drift' from side to side.
THANK YOU AGAIN~ ![]() ![]()
---------------------------------- Tim D. - Cub 1872 - Bobcat S850 - Cushman Turf Truckster |
I think that is an impulse switch that activates a latching relay. By hold it on you are continuously energizing the coil for the relay.
Any thoughts on a currently available relay? I cannot locate the factory/original part-number online anywhere (ebay, messicks, partstree, etc)
For the relays, see this thread:
https://www.onlycubcadets.net/forum/...362#post521362 You didn't mention what serial number your 1872 is, but a 1989 1872 uses a 725-0894/925-0894 relay. Equivalent to Standard RY-11, Echlin AR108, GM 2072624, Delco D1751, Kem AR161, Four Seasons 35765, BWD R367, Wells 56-1683, Duralast 19811, Santech MT0512, JD191K16.
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
