Old 11-15-2022, 08:14 PM
Club Cadet Club Cadet is offline
Cub Cadet straight 30wt in my 1810 and the 1210 it replaced. I can’t believe how much cleaner the oil stays in the M18 with the oil filter compared to the K301 without a filter.
Old 11-15-2022, 08:30 PM
Ozcub's Avatar
Ozcub Ozcub is offline
I have to mow in a temperature range between 50f up to 100f and have used 10w 40 oil as the 30 is at the top of its ability to lubricate when the temp is in the 90f and above range
This is a petrol Kohler
Oz
Old 11-15-2022, 11:38 PM
Originally Posted by 1711Cub View Post
The Kawi oil is probably as good and cheaper but I'll stick to my Rotella, + I can run it in my hydro.......But, you are correct on that being the proper oil to run in a Magnum engine.
Old 11-16-2022, 10:09 PM
ccguy's Avatar
ccguy ccguy is offline
CaseIH 30W Low Ash Oil or Pennzoil 30W Low Ash High Detergent Oil when on sale ($4 Ace Hardware). The Pennzoil is the only recommended replacement for CaseIH Low Ash 30w per CaseIH (per Hoober and Messicks).
In over 40 years of operating small engine powered equipment, I've never experienced an engine lubrication or over heating problem following the manufacturers recommendations. Straight 30W HD.
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
Old 11-17-2022, 06:26 AM
Steve N Mi Steve N Mi is offline
All of mine have in dash oil pressure gauges added to them to ensure they have healthy pressure. You can tell when the oil gets real thin after a long hard run, the pressure will drop to 40-45, when it normally sits around 50 at full throttle.
'Where oh where' do you install the oil pressure gauge? And where do you tap the engine for line to the gauge? Photos would be much appreciated. Steve
Old 11-17-2022, 08:22 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
I used a SW mechanical gauge, and a brass "T" to retain the factory idiot lamp.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 11-17-2022, 09:11 AM
Thank you 1711 Cub
That explains it very well.
Old 11-17-2022, 11:45 AM
Farmall450's Avatar
Yep I agree, also Walmart brand.
Today oils are much different and better than 50-60 years ago.
We have come a long way, oil is one of the few products we can say that about, other than medical advancements.
Yes we have.
