Old 11-20-2022, 01:58 PM
twoton twoton is offline
Some good info here if you have not seen it yet;
http://www.onlycubcadets.net/forum/s...ad.php?t=33653
Old 11-20-2022, 08:23 PM
zilla24's Avatar
zilla24 zilla24 is offline
Check that driver for cracked backing plate.
It is spring steel and not like the one pictured above.
Be forewarned, they are very expen$ive
I’m glad you suggested this, turns out the spring steel on my clutch driver is cracked in a few spots. I had given it a quick look and thought it was ok, after cleaning up the surface rust I realize I have a bigger problem now.
CC Tractors: 1650, 1200, 800, 149, 125, 86, 782D, 2072, 1572, Original
Old 11-20-2022, 08:52 PM
ironman's Avatar
ironman ironman is offline
My 2 cents....
1. Do the cradle mod...
https://www.onlycubcadets.net/forum/...ead.php?t=4630
2. Get solid motor mounts from Jeff...
https://www.onlycubcadets.net/forum/...ad.php?t=20875
3. Get a 3 pin driver for a non-quiet line cub as pictured above from a vendor or eBay, for example...
https://www.ebay.com/itm/27550890238...Bk9SR_6o_P2SYQ
But that's just me, it's your tractor.
Old 11-22-2022, 08:37 AM
The driver on E-bay looks like it needs a new bushing, so ad another $7 or $8.
And, if your 1200 has an aluminum pan, you likely have issues there as well with missing bolts and/or wallered out holes and worn mounting bosses.
All these issues lead to issues you have already discovered.
Inspect carefully.
Cracked driver plate is usually due to worn/loose bolts, worn degraded ISO mounts (they are after all nearly 50 years old) and possibly abuse or owner neglect.
Me, I'd replace the 3 pin driver, ISO mounts and do the cradle mod.
Plus fully inspect the complete drive train for loose everything, including throw out bearing, main spring, hanger assembly, teaser spring, clutch plates and disc, spirol pins, flex joints and rear coupler.
Old 11-22-2022, 09:52 AM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
Sounds wise to do a total clutch work up.
Old 11-22-2022, 11:49 AM
Do it all right.....and do it once
Old 11-23-2022, 08:58 PM
zilla24's Avatar
Thanks everyone for the suggestions. To update my progress I ordered a new solid 3 pin clutch driver, solid mounts and am waiting on them to arrive. I also trued up the pressure plates in an a lathe for the new OEM friction disc. Cradle mod and oil pan inspection are next. I’ll post pictures as things start going back together!
File Type: jpg D81F9F13-A442-45DF-92A5-CA5C634A692B.jpg (31.3 KB, 18 views)
