Old 11-25-2022, 11:15 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Exclamation
So this seems to end up as a joke every time it is brought up.
Hytran has proprietary to Case/IH additives in it to promote moisture absorption. If you change your hydro oil every couple of years, this is not an issue. If you expect your cheap oil to last 20 years, well, good luck!
We are talking the equivalent of chicken $hit money difference in cost between the two. Same to the guys that refuse to use the OEM hydro filter, and get one than spins on and doesn't leak... I know which product I will be using.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 11-25-2022, 12:16 PM
Hytran has proprietary to Case/IH additives in it to promote moisture absorption. If you change your hydro oil every couple of years, this is not an issue. If you expect your cheap oil to last 20 years, well, good luck! :BlahBlah
Oh here we go again, Green vs Red,vs Orange etc.
Ford. GM, Mopar, off shore etc etc.
Blond redhead brunet.
if it pisses someone off at a little humor, well they missed the humor.
A panther pisses, so does her cub.
Choice is what makes this a great country.
As far as water absorption, I would much rather have the water at the bottom of a hydraulic reservoir with the suction line above it,
than have it in circulation with oil.
But that is my choice and I'm not advising anyone change their beliefs.
Interesting, if a Sundstrand hydro is powering IH, then hytran is the best, if the same unit is powering a Deere then Hyguard is the best.
and on and on with all the others that used it.
Just my take.
yall have a great day, just remember do read the specifications of anything.
And don't drink down stream from the heard!
Old 11-25-2022, 01:37 PM
1711Cub's Avatar
Cool
In a typical old, not serviced when it was supposed to IH/CCC transaxle, what do you typically find?
The moisture stays in the bottom of the unit as a sludgy mess and most of it isn't dispersed into the Sunstrand because of the Hytran. Cheaper fluids just become milky and circulate all that moisture around.
Old 11-25-2022, 04:04 PM
ironman's Avatar
ironman ironman is online now
Similar to the song "There is a Mountain" by Donovan
First there is a mountain, then there is no mountain, then there is...
Substitute the lyrics,
First the Hytran absorbs the moisture, then it doesn't, then it leaves a sludgy mess...
C'mon everybody, SING ALONG
https://www.youtube.com/watch?v=lkLp9d7HKuA
Old 11-25-2022, 05:07 PM
1711Cub's Avatar
Thumbs down
YOU should explain it better, Einstein..
Maybe some clarification is needed for the smart asses in the forum. There are chemicals in the Hytran that absorb and retain the water and allow it to settle in the bottom of the diff case instead of the pump.
Old 11-28-2022, 03:16 PM
Redneck #1 Redneck #1 is offline
Attached are a before and after picture of the inside of the transmission. Had some crud on the bottom and I see there is still a little in there. Got a new filter and Hytran fluid but having a bit of trouble finding a new gasket.
Old 11-28-2022, 04:18 PM
The gasket is your standard 921-3015. It is available from your local Cub Cadet or Case/IH Dealers. It is available from our Sponsors, as well as, numerous places on the Web.
Old 11-28-2022, 04:29 PM
It might be noted.many have used RTV successfully.
Old 11-28-2022, 04:44 PM
The bolts appeared to have a Lok-tite substance on them. Is that something you would recommend?
Old 11-28-2022, 05:52 PM
From all the rear ends I have opened up, I have never used Lok-tite when I put the overs back on. I have had NO issues.
