Old 02-22-2023, 04:17 PM
Cadetpuller Cadetpuller is offline
I can pick this motor up for $125 and it starts and runs good. I think I might just go ahead and get it.
Old 02-22-2023, 06:41 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Sounds like a good price. Have fun with your project and keep us posted! pics of your project are always appreciated.
Queen Of The Quietlines!
Old 02-22-2023, 07:54 PM
twoton twoton is offline
When you remove that flywheel screen you may find that there are bolt holes in the flywheel to attach some sort of driveshaft coupler.
Old 02-22-2023, 08:17 PM
That would be great!!
Old 02-22-2023, 10:00 PM
A quick google search of the k341 flywheel reveals that it is drilled tapped for driveshaft adapter. Another google search pulls up this adapter.
Old 02-23-2023, 07:03 AM
That engine, K341S-71309 used the KH-47-025-28S Flywheel. The K341 engine had 15 different flywheels. Does the internet search show which one of the 15 is being displayed ??
Old 02-23-2023, 08:11 AM
47 025 28-S. Would this be the same one the my K341 came with?
Old 02-23-2023, 09:05 AM
A quick check on the CCC parts lookup site will answer that question as well as many others you will surely have.
Avail yourself of this asset and learn your way around on that site & place a shortcut on your desktop.
You will be using it more than once I can guarantee!!
https://www.cubcadet.com/en_US/conte...artstream.html
Old 02-23-2023, 09:11 AM
That is what I stated. I question the picture.
Old 02-23-2023, 10:39 AM
Originally Posted by Cadetpuller View Post
I'm not worried about the PTO clutch as it will only be used for pulling. Does the K341 share a block with anything that cub cadet did use that I could swap oil pans with?
So do you plan on spinning that motor over 4000?
