Old 03-19-2023, 08:45 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Wink
A couple of hours of connecting wiring, hoses and cables, it fired right up, and sounded good. I temporarily used the exhaust from the 2206. I am fabbing up the muffler setup. It drove under its own power for the first time in a long time. The clutch worked perfectly, with no slippage, noise or chatter. There is no vibration at any RPM. It's as smooth as butter. I ran it for an hour and no oil leaks. I used the throttle cable from the 2206, using the original throttle lever from the 582. I added an oil pressure warning lamp, and modified the outer air cleaner lid to fit the engine properly.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 03-20-2023, 10:25 PM
1711Cub's Avatar
Thumbs up
Modified a 782 muffler to mate with the 2206 pipe. Sounds great. I am waiting on heat shields from an 1863 to finish that part off.
Old 03-22-2023, 10:40 PM
1711Cub's Avatar
Smile
The exhaust shields from an 1863 are on. I will remove them to paint them high heat black. I drove it for 30 minutes, and all went well. The new seat is comfortable.
Old 03-23-2023, 08:47 PM
1711Cub's Avatar
Thumbs up
Got rid of the severely dry rotted rear turf tires. The 2206 engine donor tractor had a nice pair of older Carlisle USA made Ag tires in the correct size.
Old 03-29-2023, 09:23 PM
1711Cub's Avatar
Wink
New foot pad
Old 03-29-2023, 09:34 PM
1711Cub's Avatar
Thumbs up
Removed the rust, cleaned and painted the muffler shroud.
Old 03-29-2023, 09:45 PM
1711Cub's Avatar
Cool
Repainted the headlight panel grille, and the lower grille
Old 03-30-2023, 06:13 AM
One piece at at time and it's looking better & better. Great job!
Old 03-30-2023, 09:10 AM
1711Cub's Avatar
Thumbs up
Thank you!
It's coming along very well!
Old 04-01-2023, 03:16 PM
1711Cub's Avatar
I replaced the dry rotted and leaky front tires and wheels with original repainted wheels and tires from a 1989 1050.
