Old 03-23-2023, 05:27 PM
Sergeant's Avatar
Sergeant Sergeant is offline
Hey, this could be an excuse to go find You another IH Cub for Mowing or some other Brand I know there a Lot of used Green for sale down there In Georgia
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force
Old 03-23-2023, 07:28 PM
RoseHillFarmIHCC125 RoseHillFarmIHCC125 is offline
Sergeant, you’re right. I think need to find a donor or non running machine. I found a non-running 124 lawn mower tractor on CL for $200, and a non running 1811 lawn mower tractor for $400. I’d like to stay with a NF Cub since that’s what I have now, and I’ve gotten comfortable with the design. I only have one tractor, my 125 at the moment.
Old 03-24-2023, 09:07 AM
Sergeant's Avatar
How Much Property do You Have to Cut ?
Old 03-24-2023, 10:26 AM
Three acres, the goats mow the rest
Old 03-24-2023, 11:20 AM
Sergeant's Avatar
I think I would consider a Later series with a Much Larger deck than a Narrow Frame if Mowing 3 acres. I did Mow 2.5 acre In the Past with a 106 and a 42-inch deck a few times, But didn't make a weekly habit off it. Usually it was just the fall during leaf clean up as I had a 5HP Peco Bagger for the 106 from 2003 till 2010 That was My Primary Bagger system for the fall leaf clean Up Until I Bought a Power flow Bagger for My Previous JD X485 in 2010
Old 03-27-2023, 02:02 PM
Farmall450's Avatar
I used to have a couple 60" Swisher mowers. Never had much trouble with them.
They're well made machines, just change the oil and grease them (as you should anything).
Old 03-27-2023, 02:06 PM
I’d like to have at least a 54” deck. Did any IH Cubs have that option?
Old 03-28-2023, 06:56 PM
Farmall450's Avatar
Cub Cadets? Yes, 982 went beyond that to 60". Technically 50" was the biggest of the IH CC Garden Tractors. CCC had a GT54 for later models.
Old 03-28-2023, 08:36 PM
Wasn’t the 982 red? I really like those. There’s one on flea bay at the moment…
Old 03-29-2023, 09:26 AM
Sergeant's Avatar
Yes there was an IH 982 But the Biggest Deck IH made for it was a 50. The 60 inch decks Came Later under MTD but made By Haban
