Old 04-09-2023, 04:58 PM
Farmall450's Avatar
Originally Posted by 1711Cub View Post
$100 for the tractor, extra set of wheels with good chains, a good 44C deck, and a solid complete 42" plow.
Can't beat that!
Old 04-09-2023, 10:08 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Cool
I fixed the implement handle float pin. I drilled out the broken piece, and tapped it for 10-24. I made the pin from a machine screw since these pins are getting scarce and expensive. I capped it off just as original.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 04-09-2023, 10:32 PM
1711Cub's Avatar
Thumbs up
The screw on the far left is what I used to make the lift lever float pin:
Old 04-10-2023, 09:22 PM
1711Cub's Avatar
Smile
I fixed all of the electrical issues plaguing this machine. A new MTD ignition switch was installed, along with a new plug. The original fuse holder was missing the cap, and had a mud wasp nest in it. Fortunately, I had a spare cap for it. The PTO works well. A nice used ammeter was installed. All lights now work. The charging system works flawlessly too.
Old 04-11-2023, 10:07 PM
1711Cub's Avatar
Thumbs up
I replaced the collapsed lower engine mount bushings. The two front ones were gone, and the other two were severely deformed. Now there is less vibration, and got rid of a loud knocking type noise which was the engine iso-cradle vibrating on the frame under load.
Old 04-14-2023, 03:12 AM
1711Cub's Avatar
Thumbs up
It is a fully functioning mower again. The mule drive had one bad pulley, but the deck all had great smooth bearings including the idler pulley. All it needed was a new OEM belt. I also replaced the PTO to deck belt with an OEM belt. Greased the deck all up, and it mowed well. Now on to cosmetics.
Old 04-14-2023, 06:42 AM
I like seeing the progress.
Old 04-14-2023, 07:02 AM
Looking great.......what tractor will you be looking for next?
Old 04-14-2023, 07:11 AM
1711Cub's Avatar
Smile
My issue is I constantly check FB Marketplace for good deals-hence why this one came home with me. At this point I now own ten, and there is a friend's nice original 1983 782 in my shop for repairs/service which could very well end up being another acquisition.
Old 04-17-2023, 09:56 PM
CubDieselFan's Avatar
How much room do you have left?
