Did my 782, used engine muffler and everything from a 1864/3 trimmed rear of air cleaner cover to easily be moved with the firewall in place. I chose to make a new driveshadt (longer) and stuck with the same basic 782 shaft setup. Extended the starter wire and jumped the solenoid at the engine to use the factory solenoid on the tractor. Used a 5 prong relay to switch the signal from power to run to ground to kill. Did all that on the engine side of the harness so everything on the 782 remained the exact way it came from the factory except for the main starter cable. As far as the pto went I used the kt17 pto with a sleeve to make the shaft bigger. My engine was from a zero turn. But parts were 1863/4 as far as muffler and mounting plate
