Old 05-26-2023, 09:27 AM
I had a Mag 20 do the same thing. I shot some Kroil on it and used some needle nose pliers to free it up. It worked great after that. I did that with just removing the valve covers. You probably should have done a leak down test first.
Old 05-26-2023, 10:15 AM
Ian181 Ian181 is offline
I know, live and learn right! I guess that's why hindsight is always 20/20.
Old 05-26-2023, 11:02 AM
Club Cadet Club Cadet is offline
I rebuilt my M18 2 years ago. New rings, gaskets, and lapped valves. Reused my pistons. I used a cylinder hone to clean up the cylinder walls. Definitely worth the time and effort. Since you have it apart you have a great start. Since the rebuild it runs great lots of power no smoke no oil consumption.
Old 05-26-2023, 09:22 PM
Cub, that's my exact plan too.
Old 05-27-2023, 12:07 PM
I left the bottom end alone and did not split the case - end play seemed okay. I did replace the crank shaft end seals. Be careful getting the old ones out. I nicked the crank and had to use a speedy sleeve to repair it.
Old 05-27-2023, 01:38 PM
Yep not splitting the case, and definitely replacing the front and rear seals. The flywheel side was definitely seeping, not neglecting those that's for sure!
Old 05-28-2023, 09:35 AM
One other thing to look at are the pressurized oil lines leading the the remote oil filter base. Mine were a bit ratty looking and I think I had close to 1500 hours on the meter so I opted to replace mine. They were not cheap or easy to find. I know some have had new ones built at a hydraulic hose shop rather than track down OEM parts.
Old 05-28-2023, 09:39 AM
Those "oil lines" handle less than 50 PSIG of pressure. I made some from Copper Tubing with NO problem(s).
Old 05-28-2023, 09:40 AM
Great to know, and great replies guys, thanks.
Old 05-28-2023, 07:50 PM
Are you implying that there is a use for copper tubing that does not require yeast and sugar? LOL
