Old 06-16-2023, 12:26 PM
The other safety is the reverse switch
This relay has NOTHING to do with starting the engine.
Old 06-16-2023, 01:33 PM
zilla24's Avatar
zilla24 zilla24 is offline
I think the two brown wires in the picture and plug are for the oil light which is not hooked up. Looking for a replacement now as my wire leads and connector were broken off.
I do also need to have a look at the parking brake switch when I get home and verity its integrity.
CC Tractors: 1650, 1200, 800, 149, 125, 86, 782D, 2072, 1572, Original
Old 06-16-2023, 01:46 PM
Correct.
Old 06-16-2023, 03:51 PM
This is the plug, circled, I am talking about, pretty sure it needs to be connected to the switch to complete the circuit even when the go go handle is in neutral.
Old 06-16-2023, 08:59 PM
zilla24's Avatar
I do have the reverse plug hooked up.
I did realize the brake switch is definitely not hooked up. I will need to trace the wires for that and jump it temporary to see if that allows it to turn over.
Old 06-16-2023, 09:31 PM
If OEM, then it would be double Red.
Old 06-17-2023, 12:01 PM
zilla24's Avatar
Good news to report: fuel pump is on, engine turns over and glow plugs are receiving current! I bench tested them and they are good. Appreciate everyone’s help thus far!
Bad news: I have one green wire by the reverse relay that when connected is causing a short, the wires at the relay are getting hot. That is the next one to trace down, seems to me it should be grounded but clearly I have something crossed.
Tractor won’t start. Have a visible leak at the base of one of the injectors. I have to admit I’m pretty good with gas engines but not much experience with diesels. My thought is possibly clogged injectors? I do have fuel to the injectors.
Any help on next steps is much appreciated!
Old 06-17-2023, 12:24 PM
The Reverse Relay is wired as follows:
Old 06-17-2023, 09:48 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Verify fuel supply through the pump. You might have air in the system, or a faulty high pressure injector pump. Even if the glow plugs are getting voltage does not guarantee they are burnt out. Since they are so cheap, I would replace them. In rare cases, it could be low compression causing a hard to impossible start condition. With these Kubotas, valve lash adjustment is important.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-18-2023, 05:54 PM
zilla24's Avatar
Thanks for the suggestions. I checked the wiring on the reverse relay, looks correct from what I can tell.
I will be traveling for a few days, I appreciate the suggestions and will report back my findings.
